1 - 4 of 4 Posts
Hi,
I have the triple gauges for SER (voltage, Oil pressure, MPG) and I want to install it on my SE altima VQ35DE, has anyone did that before?
The voltage is easy and I’ll ditch the MPG so..
Can I use the existing oil pressure sensor?
Or should I T off of it or is there auxiliary port?
Or the last result is use an oil filler sandwich?
Thanks.
IIRC the existing is an 'oil pressure switch'...so on/off...you will need a variable output sensor to feed the SER gauge. Whether your T it or use 'sandwich' will depend on what you can make fit...I'd start with the T approach, it's got to be way cheaper if you can make the two oil sensor fit mechanically.
Cool. Let us know how you get on.
1 - 4 of 4 Posts
