1 - 9 of 9 Posts
i was driving today when all of a sudden, the stupid service engine light comes on. the car is running perfectly and everything.
i have no mods. this is the second time this has happened, the first time i just reset the ecu and the light turned off for about 1000 miles or so. does anyone have any ideas about what it could be? btw, its a 2000 se with about 37k on it.
There's been some debate whether 00-01 codes can be read manually. I'm not sure if when you reset the last code you got you just disconnected the battery. If you take a look at your ECU and see no white screw to turn, best bet would be to take it to AutoZone and have them scan it. They will pull the code for free.
last time i resetted it using the white screw, i called the dealer and they said to not worry about it unless it comes back on again
Read the code next time and let us know what it says.
1 - 9 of 9 Posts
