1 - 7 of 7 Posts
I working on my next mod of upgrading my side mirrors to turnsignals and what I need to figure out is how to remove the outside cover on the new mirror for painting ,its comes unpainted black.
I have googled ,u tubed and searched on here with no luck
This is what I purchased
http://www.carid.com/2014-nissan-altima-mirrors/tyc-side-mirrors-21874843.html
Thanks for taking time to read and hopefully giving me the direction I need
http://www.nicoclub.com/FSM/Altima/2014 Altima/MIR.pdf
http://www.nicoclub.com/FSM/Altima/2014 Altima/INT.pdf
See if these links help...looks like you have to pop the glass mirror out of the housing first to access the tabs/pawls that hold the outer cover or "rear finisher" on.
You will want to bookmark the entire manual for later reference:
Index of /FSM/Altima/2014 Altima
Ok execlent info there thanks, that will also give me wiring code to tap into in the drivers footwell/running board for turn signals.
I ordered paint from touch up direct was a bit pricy , wont be as good as factory but will half to do ,its a 3 step process.
Hopefully I dont break the mirror durring disable
2010 2.5 SL
The 09-12 popped off with a panel removal tool. In retrospect, taking the glass out first might have been the better option.
For me, removing the mirror involved reading the FSM a lot and hoping that what I was prying was correct. Very hard to see in there and the mirror doesn't really want to release.
i've always used a pocket flatblade screwdriver with tape on it to get the skullcaps off the mirror assembly, never had any problems
1 - 7 of 7 Posts
