1 - 2 of 2 Posts
I installed some aftermarket guages and they all work fine except the speed odometer....I noticed when changing it that it had a lil spring attached to the needle which in the instructions it said nothing about watching out or being careful of a spring....When I pulled the needle out it came out , so either way i was screwed...Is that my problem or could it have come unplugged from behind...Whats the spring for..tension spring maybe?
That's actually a winding that causes a spring -like tension to the needle will go back to zero when you slow down. When i put my gauges in i had the same problem so i went to the junkyard and bout another speedo.
1 - 2 of 2 Posts
