Has anyone else picked up this month's Car and Driver? There's an interesting if brief piece on speedometer and odometer error across automotive lines. Practically all speedometers are set at the factory to read slightly high above 55 mph. European manufacturers are the worst about this, with some BMWs reading as much as 9 mph over at 70 mph.
The most interesting point as relating to our '02 Altimas reading high, however, is the SAE standard to which manufacturers of U.S. automobiles voluntarily adhere. Among other things, the standard allows for a four percent (+) error above 55 mph. And get this: The percentage isn't a relative to indicated or actual road speed, but to the speedometer scale. Applying the standard to our 160 mph Altima speedometers allows for a +6.4 mile per hour reading at speeds above 55 mph. So, according to the SAE standard, our speedometers, many of which read about five mph high at 70 mph, are within tolerance.
Bureacracy at its finest, fellas.
Jarrod K. Wright
'02 3.5 SE 5-speed
'98 SE 5-speed
Jarrod K. Wright
'02 3.5 SE 5-speed
'98 SE 5-speed
