1 - 9 of 9 Posts
what is in a name?
if anyone has this set-up, did you/shop install the greddy from the end of the stillen pipe or did you/shop cut the stillen pipe shorter to put more of the greddy pipe.
just curious b/c i will be getting a header soon(prob. stillen)and was curious to how you installed.
thanks
chris
slow poke
thanks
chris
I don't think that stillen has a 4-2-1. I thought that the downpipe only reached the inlet of the cat(if you have one) and the greddy connected to the outlet of it.
what is in a name?
Red Sleeper
stillen header and greddy catback combo.....i took cat conv off cause greddy pipe about 2" too long...test pipe replaced cat.....although i talked to some people who tell me they had no prob's whatsoever...and yeah..... i do all my own install's....invest in some air tools & compresser..so much easier.
loud & proud.....car sound's mean..... :grabblue:
search the forum.....the greddy install/prob's were discussed about a week ago.
greddy catback
stillen header
pr cai w/ monster filter
swa pulley (gonna install this weekend)
stillen fstb
nokya pedals
eve stock
94_se
what is in a name?
thanks.
so no check engine light with header b/c of no cat(noticed in pick they pre-drill hole for 2nd O2 sensor)?
both bolt right up?diameter size the same from each?
I have that combo. I'm also running the test pipe by extending the greddy to the downpipe.
what is in a name?
Discussion Starter #7
dom, so you had to have extra pipe welded on?
the greddy piping was'nt log enough?
wher'd you get it installed and for how much?
thanks
chris
slow poke
i don't think it fits b/c the greddy is a cat back and the downpipe connects to the inlet. So you need to have a test pipe added on.
I'm The Yellow Member
clo007 said:
thanks.
I think it depends on the year of the car. 95-97 have an extra sensor..
1 - 9 of 9 Posts
