1 - 7 of 7 Posts
has anyone else ever had the transmission stick in 3rd gear after locking up the wheels.....when i slam the brakes it stays in 3rd till i turn off the car and start it back up again, then it works just fine till i do that again... its a 93 gle without abs
i just bought the car last week and was trying to figure out if it had abs....probably won't do it again unless i have to but just wondering if it was a sign of something else wrong or and odd "feature"
Infantry leads the way!
Look on the break Master Cylinder. It should say ABS on it if you have it. But since it's a '93 I don't think it does. Mine don't
I have a 93 also mine only does it right from when you start moving shut it down and restart it and it's fine. I've only had it happen 3 or 4 times I say get the trasmission fluid and filter cheecked a replaced if needed I did and the transmission has been performing much better. Sadly the '93s have alot of problems to do with the transmisson becase it's the frist year Nissan made the Altima.
I Don't Drive An Altima
My sister's 1999 Altima does the same thing too! Weird shit, when i slam on the brakes and tap the gas again, it violently drops to first gear and goes.
I only did it once to see if it had ABS.
1 - 7 of 7 Posts
