1 - 8 of 8 Posts
Good day to all,
Past tuesday I Bought an altima 08 2.5, when I bought it the steering had a sound, it wasnt that noisy so It didnt matter to me (thinking that if I change the fluid it would be all rigth).
So yesterday I made the change of the fluid, but when I started the car a horrible sound was singing when i was moving the steering :(
I thought if I go left to right with the motor off it will send the air away, (i saw a video). I did it didnt make a change.
I bought the PS fluid on autozone, an autozone PS fluid. Then I went back and bought an autozone ATF dexr III/merc, and flush away my PS fluid for the new ATF fluid. It didnt make any difference.
Any suggestions? Thanks.
The reservoir is with foam and bubbles.
So what kind of fluid was supposed to be in it? It's very expensive to guess on these things.
In the manual says that PSF from Nissan, (I was doing it at night) I went to autozone and bought X PSF.
Put it in > noise > autozone again > bought an ATF Dexr III >Flush the PSH for the ATF > Same noise.
I look for it on google, and found that the Dexr III was ok for Altima 2.5.
what do you think?
I looked at your Owner's Manual, on p.9-2 footnote *3 it says Dexron VI is to be used, not Dexron III. Time for a full flush and pray.
Dexron III/IV is not such a big deal. The Autozone PS fluid, from what I can tell, is mineral oil...that ain't gonna be pretty. Not sure what kind of bastard chemical children that might create in a PS pump.
Discussion Starter · #7 · (Edited)
Well, apparently It wasn't the PSF, I check all the conections, and realize that 1 of them was a little loose and the air was going in.
It has no extra noise (the noise was exactly as I bought the car). When I turn left or right it sounds a little bit what could it be? the pump?
Thanks d0ugmac for answering :)
Need more detail on the sound...rattle, hum, vibration, hiss, clank, ?
1 - 8 of 8 Posts
