I went in for regular oil and tire rotation and they came back saying I should get my throttle body cleaned.
I had a feeling they were pushing this service on me to get $, so I declined and decided to look into it myself.
Appreciate your response.
How often should the throttle body be cleaned, if ever?
My idle and acceleration are fine, so I don't think it needs any cleaning.
Also, because the SR Turbo is direct injected, is it ok to use Seafoam to clean the intake valves?
If so, where do you suggest it be sprayed into?
Thanks a bunch!
Really the throttle never needs to be cleaned unless it is causing a drive-ability issue.
Seafoam works fine for cleaning the valves at lower miles, but make sure after doing intake seafoam treatments you change the oil. A lot of the chemicals in the seafoam can end up blowing by the rings and getting into the oil.
You do not spray seafoam when doing induction cleaning, you let it get sucked in. Which is where it gets tricky on newer cars. You really only have one option and that would be the brake booster line. Anywhere else and you risk getting the seafoam on the MAP sensor which will cause all sorts of issues.
In reality: the best way to clean the valves is walnut blasting them. But this requires specialty tools and removing the intake manifold.
The best practice is to prevent the need for cleaning the valves. I cannot stress this enough: The MR16DDT NEEDS (a) catch can(s). As I linked to before I sell a can that takes care of the whole pcv system, but other brands work too. I have seen too many Jukes and Sentra Turbos come in with CHUNKS of build up on the valves, oil covered MAP sensors, and gummed up intercoolers. All of those things can be mitigated with a catch can system to prevent oil from getting into the intake tract.
