Just ordered a new OEM hub assembly from a Nissan stealership to replace the front driver's side wheel bearing which is humming like an angry wasp.
I am quite pleased that the hub assembly is bolted to the steering knuckle instead of the wheel bearing just being pressed fit into it like my 2005 Toyota Prius had.
That Prius also needed a new front wheel bearing on the driver's side BUT that bearing lasted until 240K miles before it needed to be replaced.
My Altima's bearing lasted 'only' 120K miles. Could've hit a deep pot hole here in SE Michigan - there were oodles of them last Spring. I don't
recall doing so and the humming has just become noticeable the past two weeks. Wasn't humming on my 600 mile roundtrip to the Chicago area
three weeks ago - or at least it was just starting to hum and I just didn't notice it.
I watched a few YouTube videos and it appears that the four bolts attaching the hub assembly to the knuckle can be loosened without unbolting the knuckle
from the McPherson strut. I'm going to attempt this first as three of the four mechanics on YouTube showed it was possible to loosen those bolts without extra effort.
After a simple search I didn't find more than one example of anyone replacing a front hub assembly (DIY) on a 2013 - 2018 Altima.
Nissan made a change in 2019 in the 6th gen to the knuckle/hub assembly - maybe they cheapened the assembly and just pressed the wheel bearing
into the steering knuckle like Toyota did/does - that would be bad.
Anyway, if anyone has recently replaced a front hub assembly on their 5th gen Altima, I'd like to read your (horror) story if you did the replacement yourself.
I will be sure to share my experience with it if I run into difficulty which is almost a given for this DIY mechanic.
One reason is I don't own a beefy enough impact wrench to loosen the axle nut. I should at the least rent a battery electric one to make the job easier.
