1 - 4 of 4 Posts
Upper Timing Chain Guide fix.
I just removed upper guides on my 93 GXE according to the TSB , pics soon
READ ALL BEFORE DOING THE REPAIR!!!!!!!!!!!!!
Tools need:
Marker and tape, to label
1/4 sockets 8-14mm deep and shallow
3/8 8mm-19mm deep and shallow
1/4, 3/8 u-joint socket
1/4, 3/8 ratchets and extentions
Metric wrenches, 10-19mm
PB blaster
Rubber Mallet
Gasket scraper
New gasket and gray RTV
Floor Jack and jack stand
SAFETY GLASSES
Use "common sense". Mr.Nissan not responsible if you break something or hurt yourself or others, so you are warned, this just a guide.
Loosen the 21mm wheel nut, remove passenger side front tire
Start by removing the neg battery teminal, 10mm nut
]http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA%20TIMING%20CHAIN/IMG_0234.jpg
Label the spark plugs wires, and remove them.
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0286.jpg
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0233.jpg
Remove the eleven 10mm nuts and the grommets
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0236.jpg
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0240.jpg
All nuts removed and tap the cover with rubber mallet, and pull the cover
Remove the power steering res. out of the way, pull up
The fuse box remove too, 10mm both.
Admire the engine,
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0244.jpg
With a 12mm socket, remove the guide
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0245.jpg
Guide removed
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0250.jpg
Remove the braket around the head
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0251.jpg
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0256.jpg
Remove the belts.(look at Water pump replacement, it is there)
http://www.nissanclub.com/forums/f-q-1993-2001/260688-water-pump.html
Follow that guide until the alternator, water pump can stay
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0265.jpg
Remove that bracket, it hides one bolt for the cam cover
(3 17mm bolts, they are very tight)
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0268.jpg
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0269.jpg
Now remove this bolt, the cam cover, 12mm and 2 10mms
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0270.jpg
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0298.jpg
Tap the cover, and remove it
Remove the upper guide, it held by 2 10mm bolts
http://i170.photobucket.com/albums/u245/RCM_2007/ALTIMA TIMING CHAIN/IMG_0273.jpg
Clean the cam cover and the valve cover, and the cylinder head where they join
Put a rtv on the cam cover, also put where it meets the front cover
http://www.jonko.com/auto_repair_forums/uploads//post-748-1168694261.gif
Discussion Starter #2 (Edited)
1 - 4 of 4 Posts
