1 - 4 of 4 Posts
phi phi Kappa Alpha
Okay, I have heard my chain a few times, but the noise has always dissappeared after a while. Well, I think it is back, but it is LOUD. I mean real loud, like kinda makes me cringe loud becaose it sounds like there is a quarter bouncing around in my head. I was wondering if the nosie level was normal? Also I searched, but didnt' have much time to find the guide removal write up, so if someone could post it that woulld be great. Thanks guys.
first try removing the top upper guide. you can get it by just removing the valve cover. if that doesn't clear it up, try removing the side upper guide. to get it off you gotta remove the upper timing cover. while you're in there, check the tensioner for it's cap. i had a tensioner go bad but it was aftermarket.
1 - 4 of 4 Posts
