1 - 6 of 6 Posts
my tires are bf goodrich scorchers for 19x7.5 and i have a small leak in one of the tires. i took it to expert tire but they said that they couldnt fix it b/c they didnt have the right machine to do seal the inside of the tire? should i just buy a new tire altogether??? what should i do?
try another shop, it should coast between 5-20 bucks to fix the leak instead of spending 100-200 bucks on a new tire..
does it matter if i already put 1/4 of a can of fix a flat in it??? b/c my friend uses it in one of his tires and he says that his car rides fine.
X-Mod
The fix a flat doesn't work the best in low-pros, especially if you only used 1/2 can. The tire should be repairable unless the leak is in the sidewall.
1 - 6 of 6 Posts
