Anybody?
Um, max PSI = max PSI, Jimmy. Not optimal PSI.Jimmy said:Look on the side of your tire.It should say max PSI on there
at a stop, the altima's weight distribution is 63/37PT said:If you do this to all your tires individually, you'll find that the Altima does not distribute it's weight evenly at all. All 4 tires have slightly different air pressures (at least mind does), with the driver-side front having the most weight on it.
Yeah, the Altima is pretty front-heavy (as are most front engine front drive cars... but what really surprised me was that lateral weight balance was not even... the Engineers at Nissan definitely know this because the centerline of the rear-suspension is off to one side.Ry said:
