1 - 15 of 15 Posts
I would like to know, what is the best size of tire for altima 97, i will like to in 16 inch. I think i will buy this size of tire 205/50/16, but i would like to know if is possible to fit 225/50/16 without problem with the body of the car...
Thanks
Import Tech.
Thanks
205-50-16 .. If you want 225's you will be looking at either a 225-45-16 or 225-40-16 ......
Golden Member
yeah but would fitting in 225's rub against the wheel well on a stock ride?
cheers
Dad
My wheels had 225-50-16 on when I bough them and I had no problems with clearance (I have a 97). You might want to go with the smaller size for looks though, the sidewall looks pretty tall on that size.
G
this is still what i'm debating.
i have the same rims as mrdeucie's....
i'd like to go with 215/55-16's.... but my
speedo with be a bit slow.
and i don't think 215/50-16's would look
that good, especially if my suspension is
still stock.
i think the gap will be too much if i go with
the lower profile 50 series tires.
anyone else with thoughts?
Golden Member
why do u have to use 50 profile tires?
go with 60, they wont look dumb with wide tires (215-225) and will make up the gap a little....
there is no going around it, i looked into lowering springs and short thro shocks, but i cant justify the price.... its silly i think, after all it is a family sedan we are talking about !!
cheers
Senior Member
cheers
because when you have a 215 tire with the 60 aspect ratio your speedometer will read 6% too slow
and with a 225 width and 60% aspect ratio your speedometer will read 7.9% too slow.
check this link out.
http://www.miata.net/garage/tirecalc.html
you want to keep your wheel/tire combo in the same diameter as your stock size.
ok....so what does this mean???
i did a calculation cuz i just changed rims from 15" to 16" did i improve performance by .8% or did i decrease????
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
205/60-15 4.8in 12.3in 24.7in 77.6in 817 0.0%
205/55-16 4.4in 12.4in 24.9in 78.2in 811 0.8%
1 - 15 of 15 Posts
