1 - 3 of 3 Posts
I need to get new tires on my stock SE rims I have 205-55-16 can
I put 225-50-16 I saw a tires By Bridgestone RE 730 will this fit and will my car feel good?
Infantry leads the way!
They shouldn't feel much different than what you have now. But I believe 225 will fit with no problem.
Member
It will fit but it also might rub a little which you can roll the fender if that is a problem.
Your car might be a little rougher than before cause you have less sidewall but I doubt it will make a hugh difference.
1 - 3 of 3 Posts
