1 - 7 of 7 Posts
Title beneath my name
i was wondering how the protorque torque converter actually works...like what does it do to my car, make it faster, make the engine more efficient...what does it freakin do???:p
as you can tell i don't don't know much about cars:D
does the torque converter increase or decrease gas mileage?
is this something i should think of getting???
and from what i've gathered from other post i should get i/e/h, but what else should i get a pulley, wires, new plugs, new ignition thinga mah jigg???
thnx for the help
well i have a 97 with a torque convertor and it really helps out
off the line when you rev the gas it will only rev to like 2200 but with this it goes to 3000 and you get a better start.
i mean when you give it a lot of gas while braking at the line
What did you have the stall speed set at? I was asking about this a couple of days ago. Heres the thread.
http://www.altimas.net/forum/showthread.php?s=&threadid=1300
hard on equipment
osama said:
I think the short answer is: TC act as the "clutch" for an auto.
That's correct. What the aftermarket torque converter does is change the stall speed on the transmission, meaning your engine will rev higher into the rev band before it shifts. It's also a more pressurized unit, so it gives better response leaving the line in first gear. It shouldn't be too hard on the engine or transmission, but it would almost definitely require an automatic transmission fluid cooler.
1 - 7 of 7 Posts
