1 - 7 of 7 Posts
no ordinary sedan
Hey guys...
We're trying to change the tranny oil in my car - and we found the drain bolt but its a FLAT screw with one thread in it.. you would have to use a regular screw driver. Are we not looking in the right area or did someone replace the factory one with this one? :confused:
projected member
look between the trans and engine at the bottom. right next to the crossmember is a 12mm. bolt. thats the drain plug. the fill plug is at the front of the trans with a 1/2" square hole, just use a 1/2" ratchet or a breaker bar.
projected member
the 1 with the flat head youre looking at is prolly for the rev. lock out assy. inside the trans. you wont be able to take it out anyways because theres a pin in it on the inside
1 - 7 of 7 Posts
