1 - 5 of 5 Posts
So im ll ready to change my tranny fluid last night but wanted to make sure i had everything i needed. I checked on here and found Nissan calls for 10 quarts of fluid. I only bought four b/c thats what i was told to buy at the store. Well how many? Ten seems like too many and someone else was mentioning that is only what Nissan's Max Capacity is. Anyone know?
10 quarts is the capacity, but all of it doesn't drain out when you do a simple change. Measure what you drain out and replace with that amount.
Resistance is futile
nizzmo96 said:
hey did u buy the filter too.. cause dont u need to change the filter too
Not "user serviceable". Best way is to have a shop flush and refill. I added an external filter kit from Summit that I mounted right below the battery. Takes a large common twist-on oil filter.
1 - 5 of 5 Posts
