1 - 9 of 9 Posts
the trailer's rockin
my auto tranny only has park and forward gears. no neutral or reverse. i also got a check engine light with the code 1107. this all happenned when i got stuck on a patch of ice and had to get pulled up the hill! the description i found for this code is "A/T TCC S/V FNCTN" anyone got any suggestions??
AKA Howey Feltersnatch
damn dude, you live in alaska?! so even when you put the car into neutral, it still rolls forward?
that's correct, neutral acts just like drive, and reverse acts just like park! i'm goin now to see if my tcu gives any info!
Resident NICO Mod
the code you listed there is listed as a 1204 which is a torque converter clutch solenoid valve code.
-AT control unit detects the improper voltage drop when it tried to operate the solenoid valve.
Discussion Starter #7
does that mean i need to replace the tc? also i have 11 long and 7 short flashes
Resistance is futile
That's freaky. Mine once got confused and only had park, reverse, and third. That is, starting up from a traffic lite it would be in 3rd, not 1st or second.
I disconnected the battery overnite and fortunately it was all better. A free thing to try.
1 - 9 of 9 Posts
