G
Guest
·Just a heads up to others. It is bad enough that reading the oil dipstick is somewhat of a pain. The other day I went to check the transmission fluid and at first I thought I was running into the same problem. Took out the dipstick and it was dry! First I thought it was me because I didn't have my reading glasses on but in reality, I was a quart low! This is really great. I had the car in because the transmission shifted poor and jerked. According to the service department they checked it out with the consult and checked the fluids. Why don't I fully believe that they checked the tranny fluid. Anyway, it took almost a quart and just like the motor oil, you don't get an accurate reading after you put in oil unless you let it sit and all the fluid drain down the tube to the pan.
You might want to check out your fluid levels in particular since it looks like some people are starting to have transmission problems.
