1 - 3 of 3 Posts
Any recommendations here... I have replaced the transmission in my 04 maxima, now it has all gears when manually shifting, however will not shift on its own.. could this be the TCM?? before replacing the transmission it would shift from first to second, then lost everything from there... anyone have this same problem ever???
Discussion Starter · #2 ·
I have looked into maybe resetting the TCM, have also looked into ordering another TCM, just wanted to see if anyone had any recommendations for this, as I would rather not keep racking up higher repair bills if it may be something easy to reprogram or replace... no codes are showing up and the SES light is not on either, the replacement transmission had 60K miles, when manually shifting it does ok, but in drive it stays in one gear...please help!!!!
Camshaft position sensor or crankshaft position sensor could be faulty but not producing a code for some reason
1 - 3 of 3 Posts
