1 - 15 of 15 Posts
I'm considering a 2016 Sentra S, but one thing I (and apparently a lot of others) don't like is that the trunk taillights are only reflectors and don't light up.
I found a solution here: http://www.aliexpress.com/item/1-Pa...49&btsid=458e6abf-2325-4320-a2bc-831737b9727b but I have several questions - combination of my inexperience and Engrish on the website.
First off:
  • What exactly changed on the 2016 taillights? I know the outer taillights changed in that the clear portion doesn't wrap as far forward, but was the overall shape and the inner (trunk) portion of the taillights unchanged?
  • I thought the trunk taillight had the reverse light, but from the FSM, it looks like the inner light is only a reflector and all the OEM lights are on the outer light.
Now from the ad … I can probably figure out how to wire this up myself when I have the lenses in hand, but I would like to know how they work first:
  • First picture says "Daytime Running Lights show" - I assume it means tail-lights show - there shouldn't be any connection between the DRL's and the taillights - correct?
  • Third picture says "Fog Lights Show" and shows a yellow light between the clear lens and the outer LED's. I would prefer the clear lens to light up with the reverse lights, but it doesn't seem to, but I can live with that. I assume it means turn signals by Fog Lights (unless it means European/Japanese reverse fog lights), but … I also assume I can de-pin that wire if it do NOT want those lights to come on. (Also - I can't really see how this would work - there isn't an easy way to get yellow light from behind a red lens - the best you could hope for would be orange if you used yellow LED's - I'm ASSuMEing that's what was done here, but …
  • I'm hoping these lights just T-harness between the tail-light socket and the tail-light harness connector, but it is hard to tell from the images.
  • The images have a watermark for Dolphins E Life, but my Google-Fu failed me on that ...
Thanks in advance for any assistance ...
Discussion Starter · #2 ·
Answering some of my own questions ...
I contacted the seller and got a (not unexpected) less than satisfactory response:
yes,sir,these fit the USA 2016 Sentra
and no more orange.
and the picture is the installation detail
Now - these would look great on the 2013-2015 Sentra and would be highly recommended. On the 2016:
The design of the outer tail-light is changed, not just the lens color.
These might FIT on the 2016, but IMHO, they won't look good on the 2016 - unless you swap out the outer taillights for the 2013-2015 ones, and I'm not sure that is possible.
I still don't see how you can get a yellow light output through a red plastic lens. (Actually, in the image I posted, those look yellow also, but I'm sure the 2016 OEM has red tail/brake lights).
The installation instructions say to plug the wiring into the fog light power plug, but I HIGHLY doubt I have to run a wire from the front bumper back to the trunk ...
Not an unregistered user
The 2016 tails have halogen bulbs for at least the brake lights, so it looks like Nissan has done away with the LED's. I have no idea if the 15's would fit the 16's, but I doubt it.
Discussion Starter · #4 ·
Didn't realize they went back to halogens for 2016 - too bad ...
That's what it looks like, anyway. I'm a little unclear, though, as Nissan's website has "LED Taillights" as a standard feature for just the SR. I looked at a '16 SR and SV parked next to each other. I don't recall seeing different taillights on the SR, but I could be wrong. Hope I am, actually.
Discussion Starter · #6 ·
From the image above, it looks like they have some sort of "light bar" on the 2016's, which I would assume was LED - but the lower lights might be halogen.
Why would nissan change the brake lights?
The semi-square config of the LEDs is unique and very effective already. I always look at the new sentras on the road while I'm driving, and when they pass by me, the brake lights are so clear and vibrant that I can recognize them from afar.
You know, this is actually fairly common. It seems like a lot of facelifts/redesigns end up with LED brake lights getting dropped. A few examples: Honda did this with the Accord, VW did it with the Passat, Toyota did it with the Camry. BMW did this with the 3-series, also.
To answer your question, I think it's to keep the pricing competitive. Nissan added quite a few features to this car for 2016, but still need to keep it attractive when shopped against a Corolla, Civic, etc. That being said, I don't see LED tail/brake light assemblies breaking the bank, so to speak.
This sort of thing:
1 - 15 of 15 Posts
