1 - 3 of 3 Posts
For you turbo guys, do you run stock fuel pump/injectors? And do you use any kind of fuel management such as Apexi's AFC? Was just curious, thx.
I used to have an Altima, but never got around to turbo'ing it. I was going to get the Fmax kit. One reason I sold it was because it was an automatic, and I really wanted a 5 speed.
Incognito
you can run the stock fuel pump. I have the stage II kit, which includes an upgraded fuel pump. also, 660cc injectors are way too big if this is your daily driver unless you've got a stand-alone ecu. I have 550cc injectors and have juat a little bit of sluggishness due to too much fuel and not enough go. once I get up to speed, it's fine, but stop and go driving sucks for big injectors.
Thanks for the info.
Most of the 16G turbo guys are running 550cc injectors. The turbo I'm getting flows 680cfm! I think the 660's will be good. I have an Apexi S-AFC to control the fuel. I plan on running about 18psi on the street. Here's a link to the turbo if your interested. It's good for 350HP on pump gas.
http://www.hrchahnracecraft.com/hahn/parts/s20g.htm
1 - 3 of 3 Posts
