1 - 2 of 2 Posts
Post accident and repairs to front left QP, the right front turn signal is flashing to fast. Both head lamps were replaces.
Does the is car have a flashing relay for each side? If so, is it under the steering column?
I've seen post on the net about a BCM module. Could this be my issue? What is the BCM module and where is it located?
Thanks, Sproket
Check your rear bulb. Usually quick flash is a warning that you have a bulb out.
No relays, all flashing is controlled by the BCM which is buried way back in the dash behind the cluster gauges.
1 - 2 of 2 Posts
