1 - 5 of 5 Posts
i have been asking this question for a long time but no one seems to want to answer it. how in the hell would i connect power to a monitor or two. and also how would i power the dvd player
Cub Fan, Bud Man...
With electricity normally. This can be supplied by either an electrical outlet, or by lightning. If you chose the 2nd option, its wise not to be in any sort of water. Bad things could happen. VERY bad things.
j/k :)
Is the dvd indash? If it is, then you should just be able to hook it up as you would a stereo.
depends. If it runs off 12v, just wire it up to almost anythign in the car (cig lighter would be fine for lcd's). If they need 110 power, then you need to purchase an inverter. You would wire the inverter to a 12v power source and plug in any 110v devices. Simple ;)
1 - 5 of 5 Posts
