1 - 2 of 2 Posts
Torqueless wonder...
I need to replace mines and I was wondering the following.. can someone please answer this for me... Thanks...
1) anyone know the part # to it?
2) how much would a dealer want for them?
3) are these the same from 93-01? I saw a pair the belongs to a maxima and it looks like it's the same...
4) Is it safe to drive with only 2 bolts attached on one side? I'm afraid if I drive too hard the spring might pop out...
missing El Polo Loco...
2. KYB sells them for 40 bucks a piece, so i imagine nissan would want $60 for it.
3. yours is a 2nd gen, and since even the strutbar from 2nd gen doesn't fit the 1st gen bolt pattern wise, I'd say not the same.
4. the spring won't pop out, but the whole strut assembly might pop out on you if driven hard enough. 1/8" of still is 1/8" of steel.
If you cross-threaded the one stud without nut currently, you might be able to get away by just re-threading the stud with a die, available from the hardware store. if you broke the stud however, then you got to get a new top strut mount/insulator.
1 - 2 of 2 Posts
