1 - 12 of 12 Posts
Erect Member
now that i have my engine back together. ive determined that im one tooth off on both cams. full advance on the dis only gives me 20 degrees. will i be able to pull the exhaust cam gear ONLY pulling the valve cover, and NOT the upper timing cover? will i be able to take the pressure off the tensioner with, lets say, a long screwdriver? when i had it apart, i never thought to look and see if it could be done that way...and i think i can get a thin breaker bar on the cam gear bolt. i just dont want to tear this shit down that far again, what a pain in my ass.:angry2:
Import Tech.
Yes , youu can remove the gears with just the valve cover off , once you have them set right , you just use a large screw driver or smal pry bar to push the tentioner back into itself , it will want to spring back , it takes about 4 hands to do it , but it can be done !!!! I have changed cams ( adjusting valves ) without removing the upper cover many times
Erect Member
kewl! thanks bro, it was enough work the first time... just to HEAR that someone did it is enough for me at this point. ill figure it out then, thanks.
dismember
u can do it :eek: ur car is bein such pain in the butt :(
Erect Member
dont i know... :( you know why? it wants that 2000 engine... it can practically SMELL it.
dismember
w0rd up! da tranny is miiiine :D
dismember
lol, wouldn't it be incredibly funny that my car would be faster with that tranny ;)
Erect Member
Discussion Starter #9
hehe, NO. if i get that engine, its getting the whole head job. ( i said head job ;) ) ill make sure that ****er is faster, lol.
dismember
gawd dammit, i guess i need to get an extra head to mod too :mad:
1 - 12 of 12 Posts
