1 - 13 of 13 Posts
Die Trying
it sucks, don't bother with it
if you want a plug-n-play module, go with the JET V-force. it's seems to be a little better
Nissan God
worst waste of $300 imo, get a S-AFC, that will yeild far better results
Member
Detail Description:
The VENOM 400 constantly monitors the vehicles throttle position senor (TPS) and manifold absolute pressure (MAP) or air mass sensor (MAS). When airflow entering the engine and the throttle position sensor reaches a predetermined level, the VENOM 400 is activated. The VENOM 400 then enters a strategy of sense and modify. It senses the sensor values, interprets them, then modifies them to increase performance. The existing on-board computer senses the modified values and increases fuel flow, modifies the ignition spark curve and transmission shift point (on automatics only). Once the sensor valves return to normal mode (like idle), the VENOM 400 switches back to sense only mode until conditions again warrant the high performance mode.
Shadetree Mechanic
Rip..........
EAT IT
yea what he said
Beantown Punk
my friend got it installed in his firebird and i didnt notice any really noticible gains...more seat of the pants dyno than anything
1 - 13 of 13 Posts
