do lots of research .once i do all this work i will have another car but i would like to make it drive ably everyday if need be. what in your opinion is the best streetable cams?
but yup i know iam going to need a tune once those cams are in thats why i havent tuned the car yet cause iam just gonna wait till i get them. so the UTEC for 350Z for sure works on our car? thats mostly likely what i will look into unless something else comes out down the road
the actual specs of your motor should be decided by you and your engine builder !
usually , the higher the duration the choppier the idle , with any cam upgrade you will most likely have to up your idle by 100-300 rpm . if you want to have a redline over 7000-7100 you will need better valve springs . remember there is more to cams than duration and lift . there are alot more companies that make cams for the VQ35 , also check out Tomei , JWT , Cosworth , HKS , Kelford , etc , if you are going to build it right , build it with the right parts and sometimes they cost a little more .
p.s. wanting to spend all this money , why do you prefer NA and not just go turbo ?
