1 - 4 of 4 Posts
I went ahead and did a VSS bypass for the stock navigation using a rocker switch. I couldn't find much in the club about 2013+ navigation bypasses so I thought I would give my .02.
Quite an easy mod with superior gain. I saw the "Prestige" post but paying $150 for something that costs $5 is crazy to me.
A simple split of the VSS wire spliced to the rocker switch gives the same outcome!
^^ I don't know why those two are so bitter, but you can ignore the dire warning...you just modified the body harness, not the unit itself and did so in a passive way, no different than unplugging the unit in effect or mouse chewing through it. Be pretty tough to deny you warranty service unless you did a crap job and something shorts to ground/battery and then stops working.
1 - 4 of 4 Posts
