Hi all, after a hard rain I had a couple inches of water on the front driver side floor. Put new molding on both sides. Could it come in anywhere else? Same ? for the trunk. I think I'm goin to replace that seal too. Any ideas? Thanks, rj
mine leaked hella after i put on my Se-l's. so i had to use the supplied sealent...Chris said:For the trunk, check the sealant around the tailights. That's a known spot for leaks, especially if you've changed your tails.
rj752 said:Chris, as a matter of fact, I just had the taillight replaced. What kind of sealent shoud be used and where does it go? Thanks
Any kind of sealant will work. Just cover around the dges real good.rj752 said:Chris, as a matter of fact, I just had the taillight replaced. What kind of sealent shoud be used and where does it go? Thanks
