1 - 7 of 7 Posts
i just tapped into my cigarette lighter for a 12v source for my LED kit.. .and now my radio doesn't work.... the fuse is fine.. i checked... should i go to a higher rate fuse?... what should i do?
carputer owns you
disconnect the new wire and see if your radio comes back. If it does then the wire is your problem. If not you have some other problem.
is there anyway i can fix this without undoing what i did?.. it didn't work BEFORE the install... but it worked when i got the car
-Chris
correct.... but it DID work when i got the car.. and about a month or two after that.... but the speakers (could be bad wiring) .. when music played.. they would crackle and the front speakers would turn off.. but the back speakers would still play.. what's going on?.... could it be that just my head unit is fried?.. then why do the lights still stay on?
-Chris
1 - 7 of 7 Posts
