1 - 4 of 4 Posts
I have heard a few people talk about the transmission slipping.. what does that mean exactly? Also, if the transmission is slipping does that indicate that the transmission is about to go bye bye...??
Most noticable when the car changes gears. Like from 1st to 2nd...usually shifts around 3000rpm right? And usually a quick shift. Slipping would be when the rpm goes from 3k in 1st, 3.25 while switching, and 1 second later, 2k and in 2nd gear. Basically, tranny isn't quite grabbing the next gear.
Try flooring the gas and see if the gear changes are quick. Oh yeah, I assume you're refering to automatic and not 5sp...cuz 5sp clutches slip...kinda similar.
Jay
UMMMM
that means that u been luther droppin too many tyms....neutral droppin and shiftin' into gear.................
:D
1 - 4 of 4 Posts
