The SE Altima engine, utilizes a variable cam timing on the intake side only. As mentioned above the ECU uses variable, such as RPM, Throttle Position, Temp, etc, to constantly adjust the mechanical timing of the intake camshafts. It is equivalent to have adjustable cam gears, that are dialed-in for peak torque at all rpm's (i.e. 1 degree may yield peak torque at 3000rpm, but at 7000rpm it my be 5 degreees, and the variable cam timing would provide just that, 1deg at 3000rpm and 5deg at 7000rpm)
The SE engine also utilizes an intake manifold that has two paths to the cylinder head. One path is long and small flow area, which is good for low rpm torque, and another path that opens up the flow area and is a shorter path to provide the motor with the air it needs at high rpm, just improving high rpm torque.
My guess is anything you may "feel" is going to be the when the additional intake runners open up on the intake manifold.
