1 - 6 of 6 Posts
Big balla
audiobahn 2150hc amp- specs are
150 watts x 2 @ 4 ohms stereo
300 watts x 2 @ 2 ohms stereo
450 watts x 2 @ 1 ohm stereo
1200 watts x 1 @ 1 ohms mono
rockford fosgate power hx2 rfr3112- specs are
150-1,000 watts RMS * Peak Power 2,000 watts * Sensitivity: 88dB SPL * Dual voice coil design (two 2-ohm voice coils)
my question is, since the amp is 1ohm stable and the sub is 2 ohms would that not be a good combo? or would i have to wire it differently? some one help me out! thanks. erik
the sub has dual 2-ohm voice coils...that means you can either wire it to 1 ohm or 4 ohms...should be a good match if the audiobahn puts out what it's rated. I'm not too familiar with audiobahn amps but I don't like their subs.
Big balla
ok that sounds like it will do good then, thanks. how would u recomend me wiring it up to 1 ohm?
1 - 6 of 6 Posts
