1 - 5 of 5 Posts
ok.. i'm planning to install some devices that require power..- -
but the only place i know is the headlight wires and the brake wires.. is there like "the source" for direct power? If so.. where can i find it and wire it to? Thanks
lee, check the wires in the back of the fuse panel. Depending on how much power you need these should suffice for most low power applications. If the consumption is going to be on the high side go directly to the battery.
could u please explain this to me in detail neone??
I'm really bad with wires.. How would i connect it straight to the battery and get the wires through the firewall and into the interior?
Be shure to use a firewall grommet so the wires will not rub the firewall and short out.
1 - 5 of 5 Posts
