1 - 7 of 7 Posts
My dealership has a very nice '93 AltGXE with a 5-sp and about 80k. When cold, I mean really cold, it won't idle. If you hold the throttle a little it's fine, and it doesn't hesitate off idle. Once even slightly warm it idles perfectly.
What should I be looking for/at?
Thanks in advance.
Not doubting ya teamfresh, but is that a definitive answer?
personal experience?
I guess I'm just looking for a "why".
my alty does the same thing. that was before I lost my oil pump. The mass air flow sensor picks up more air, and has a problem regulating the amount of fuel to mix to have the engine idle correctly. Mine started doing it as soon as i put a High flow air filter on it. Basically, I just let the motor warm up, and i don't have a problem. Mine usually stopped after I drove about 1/2 mile and the computer learned how to regulate things.
so buying another one may cure me?
Will my ECU need to be recalibrated to the new(probably used) MAF?
Thanks again
1 - 7 of 7 Posts
