1 - 3 of 3 Posts
96 sentra 1.6 auto 4 door
why on my6 96 sentra do i have 14mm rack end threads instead of the 11mm? i am lolst on what to do other than remove the whole rack n pinion and investigate so i cab get parts ordered that fit.
If you're not the original owner, it's possible the previous owner had replaced the full rack/tie rods with an aftermarket unit.
That is likely the case, i will look into other models and years with compatible parts to see which one has 14mm wide threads.
1 - 3 of 3 Posts
