1 - 16 of 16 Posts
Cube Farmer
ZEX... i just found an old roll of film and this was on it.
Rollin' On Jordans
R.I.P.
Cube Farmer
Discussion Starter · #8 ·
osama said:
SuperStyl, get on msn when you can, I still need to ask you some nitrous questions.
I never see you online though...
Import Tech.
Rick said:
gee, it looks like the back cylinder went a little lean :)
Sorry but thats the front cylinder .....
donor cycle
osama said:
can the #3 go lean, or is always the 4th one on a wet kit?
it would be the #1 cylinder that usually goes lean :D (furthes cylinder from nitrous nozzle) but the circumstances that your engine falls under, anything could have happened to your motor... my old motor has no compression in any cylinder...
Cube Farmer
Discussion Starter · #14 ·
oh... that pic was scanned on a cheap scanner... so the pic is actually a mirror image....
350Z
that's more realistic than #3 cylinder losing compression though. Can this happen due to stress on the motor (pistons weren't burnt)?
Shadetree Mechanic
Shitty!
Sorry bout the piston problem bro! What did you replace em with? I used je ! what's your compression?
1 - 16 of 16 Posts
