So i recently had to change out the shift solenoids (All 8) because it was stuck in 5th gear, well after doing that its still stuck in 5th gear and whenever i connect my code reader up it still gives a p750 code ( Shift Solenoid A)..So i dropped the transmission pan once again just to double check my work and everything is in its right location, i rechecked all the connection and they were also fine. So i put everything back together and put new transmission fluid back in, Which makes the second time ive filled it up..So now its still stuck in 5th gear and im at a lost of what the issue might be. Now it does have over 230,000 miles on it but the transmission has been rebuild not to long ago, maybe 3 years ago.. ANY HELP WOULD BE GREATLY APP
