2010 Reverse Light Wire Color at Kick Panel Location
1 reading
13K views 5 replies 2 participants last post by  BigTw1st
#1 ·
Hello,
Can someone verify what color the wire is for the reverse light? I am going to tie into it for a back up camera --- I am doing this at the front of the Altima 2.5S at the driver's side kick panel location.
I would appreciate it very much if I could get the wire color -- I will still probe it to check, I just need a starting point? Thanks!
:grin
Discussion starter · #5 ·
Thank you!
Yes, I got it connected -- and with the final install of my Jensen Head Unit my back-up camera works GREAT!
And yes the wire for the reverse light was the Violet Colored wire -- and I used a 3M Tee-Tap to tie in the wire provided with the "Ready Harness" provided by Crutchfield. The guys at Crutchfield are great professionals -- the wire that was labled Reverse Wire in the Crutchfield Ready Harness was even VIOLET! Pretty KOOL!
I have a lot of pictures of the rear camera install, and the Head Unit install -- I hope to be able to make a slide show with all the pictures.
Thanks again!
