21 - 37 of 37 Posts
Discussion starter · #21 ·
Sorry...got this a little late this evening. Looks like all is good now.
It's all good, not outta the woods yet. If I can't figure out the windows I will shoot you a pm.
Also, thanks again for the speakers. Sounds ten times better now. Was kinda weird tho because even though some of my old ones didn't look blown, no tearing, they definitely sounded that way.
Discussion starter · #23 ·
Let me know if you need pix of the window harness. I took pix of all the plugs behind the door panel.
Will do, luckily though the only wires that totally came out are the ones you posted. I think maybe the others are just loose or something. After the sharks game I'm gonna head into the non-insulated frozen garage and give it another go.
Discussion starter · #24 ·
Thanks a lot guys but unfortunately it seems to be something else although I am not sure what it could be. The windows want to roll down sometimes but only when I hold it at an angle of some sort. Checked the connections on the whole thing there and everything is on tight.
Connected all the wires in the correct place as is in the posted pictures but nothing works now that I put it all back in. :banghead:
Off to the auto repair shop! :eek:wned:
that sucks....I would be pissed. hopefully it's something simple and cheap
What all is not working?
Mirrors, windows, door locks? And are they working on the other doors?
I have that whole switch assembly if you need one. PM me.
Discussion starter · #27 ·
Well, this just got worse. Just checked BT and nothing works on any of the doors lol. Maybe blew a fuse somehow connecting and reconnecting things. Doubt it is the power window lock because even the power door locks don't work on the passenger side. Shucks.
What's weird is that they will work if I am pressing the brown connector in really hard while holding it up. But it isn't loose. Not everything will work when I do that either so it may not even be me pushing in on it that's having an effect. If that's also the case it probably isn't a fuse either because if it was blown nothing would work ever. Damn, I am lost haha I hate electrical messes.
Discussion starter · #28 ·
Quick update. Now the dash doesn't light up. Odometer is blank and the lights that illuminate the speedo and tach aren't working...and my radio and all of the lights there are also off until I turn my headlights on. Shat. Time to go to the shop.
Find the fuse under the dash that says battery saver, but I think your problem is going to end up being a bad BCM....:sad:
Discussion starter · #30 ·
I just don't get how it could be something other than the wiring since if I hold it a certain way the windows and locks work. But then the radio and dash shouldn't be fubar'd if that was the only problem.
Just to clarify, if it is the bcm then this is all I would need to fix things?
2002 NISSAN ALTIMA BCM BODY CONTROL MODULE
That isn't as expensive as I thought it would be.
So as usual, I go to fix 1 thing and break something else.
Anyways, does anyone know where I can find a diagram showing which wires go into which slots on the drivers side window connector? I am talking about the white clip you need to take off in order to get the door panel off. It has 7 wires and isn't labeled. All the wires came out when I was removing the clip.
It would be the top connector, not the brown or the middle small white one.
I need to in w how they come out of the electrical connector. Do they have a push button like a land line? Pull straight down. I'm trying to not break anything hing. Or better yet my drivers window went down and won't come up.
That may be a mechanical issue with the regulator. The wires always snap in with some sort of escapement latch, you have to look very close at the connector to tell what type, it varies depending on the wiring vendor. A dentist pick will often pop them loose.
21 - 37 of 37 Posts
