TPMS Sensors problem with 2012 Nissan Versa
2 reading
2.5K views 1 reply 2 participants last post by  Throckmorton
#1 ·
I have Nissan Versa 2012 , TPMS Sensors are check by Mechanic Good, Tire pressure is Good.
Mechanic Reset TPMS light. It work for just 10miles and Light came back . What could be problem .
How to fix it. Approximately how much it will cost to fix it. Any suggestion?
#2 · (Edited)
Have you replaced your 10 year old TPMS sensors? Are they OEM? If you have not replaced them, they are at the end of their life cycle. The TPMS batteries are not replaceable.
Here is what is happening. When they tested 'good', it was with a reader placed close to each TPMS. However, they are too weak to register properly with the car, hence, the illuminated TPMS light in your dash.
Solution? Replace all 4 TPMS units and have your system reset.
