Verdict on NGK Spark Plugs: Iridium or Platinum?
43K views 31 replies 18 participants last post by  amc49
#1 ·
Hello all,
I've done a ton of searching but haven't come to a clear verdict on what the consensus is regarding whether to use NGK (9029) DILKAR6A-11 Laser Iridium Plugs or NGK (6240) PLFR5A-11 Laser PlatinumPlugs
what are the thoughts/experiences? I'm around 100k so I'm planning on doing this sometime this month. Also, any recommendations on where to get them? I've been buying from Courtesy Nissan..
#4 ·
My question is what is wrong with OEM? They are around $11 ea. at Advanced Auto and last 100k+ miles. Searched the part number from the Owners manual on their site and got 6 for around $60 last summer. I had 120k miles (6 years) when I changed mine and the guy that helped me said they still looked good. (He's a retired HMMWV mechanic from the Marine Corps) I'll sell the car before I change them again.....I hope.
Just go OEM. What will it hurt?
#7 · (Edited)
#12 ·
When it was time to replace my plugs (75k miles a lot of track time) it already came with NGK (9029) DILKAR6A-11 Laser Iridium Plugs stock (I'm the sole owner)
Personally I'd just get stock spark plugs, it's not a big deal for daily driving
#15 ·
Don't know OP's car year or where he's from. Rock auto has the NGK Iridium plugs for 09 at $18.54 CAD.
#20 ·
#25 ·
Also please regurgitate into my mouth like a good momma bird does....
:lolrun:
#22 ·
Depending what you have done to the car determines what spark plugs will work best for you. If your car is bone stock, there is no reason to get anything better than platinum since those are what stock plugs are for a vq35de. If you install iridium plugs on a stock motor it will run a little more rough for daily driving. However if you have mild bolt ons on the car irridium plugs are the best choice. But in reality both plugs are an ideal replacement if your car at least has an intake and an exhaust. It really wont matter untill you have a tune.
#23 · (Edited)
I changed mine in the 4banger last yr. and got the OEM's, actually not sure which ones they were. Yes, I have CRS (can't remember shit) syndrome...getting old sucks.
Anyway, with newer cars it's always better going with what is engineered specifically for your ignition system. Hell, it's only 4 plugs, who cares if they're $10, or $15 or $20 each since you can change them all in less than 30 min.
#27 ·
I know most are okay with Platinum's or Iridiums.. I called 3 Nissan dealerships and they said that the stock plugs are NGK Platinums, not Irisiums. I suppose both work fine, but I wanted to go with what lasted me 100k.
I ended up pulling the plugs out of my car (08 2.5 SL Auto) and they were NGK Iridiums, DILKAR6A11. I went with those plugs from Advance Auto Parts. ~$16/plug and they have a 35% off discount code.
Thanks all for the input.
#28 ·
just throwing it out there, the spark plugs are meant to last around 105k miles depending on your driving habits.
#29 ·
I have used both NGK Platinum and the OEM Denso Iridium Plugs.
Bought them both from Rock Auto, paying 13 for Denso and 16 for NGK. Theres no difference in power or mileage or anything just in your head. When I change the Plugs on the 6's at work we use the Denso anyway and were Nissan. I love NGK I really do but when Nissan has to outsource and get Denso Iridium Plugs for our 3.5 Altis thats when you know there good and needed and what is required by our cars and Nissan. Trust me if Nissan could save money and put cheaper/other plugs for our 3.5 they would but they cant and outsource to Denso
Save your cash and your time. Your paying for the NGK Name. Buy the Denso. I have them and did my plugs and the only thing we use at Nissan. Did my plugs at 120K and the plugs looked ok, not great, but not crappy either and I applaude Nissan for finally balling up and putting a good plug in
Save your cash, get the Denso. I use them all the time at work and on my car as well. They will never give your problems and give you 1-3 Bump in MPG as well since there new and freshly gapped and carbon free.
Enjoy
#32 ·
Maybe $3 each, they are 30K mileage plugs.
Any NON precious metal plug is good in most cars for around that much mileage. Plats are about double the price and extended mileage to 50K or so. Iridium are much more expensive but are the first 100K mileage plugs, you never saw extended OEM plug change mileages until they showed up.
ANY good new plug will perform close to the same, the big difference in life is in how fast the electrode eats down to change the gap faster or slower. They do that by getting made of harder material that does not melt as easy. Take a file to a plat plug and then to iridium, the latter is harder than the file.
The low spec plug mentioned above will file down like made of butter and why they don't live very long.
