Thanks for the reply foreverfalcon40
The new one from Nissan (took a bit more time then they said) should be here tomorrow. I made a 225 mile trip with it like it is and it did great. Before I left I pulled the coil and there was very little oil in the tube but I cleaned it out anyway. Once I got to my destination, I checked and it only had a little bit of oil at the bottom of the spark plug. Following advice I found on this forum I cleaned everything with a little brake clean on a rag and then put a good bit of dielectric grease up inside the tube to prevent oil from seeping up inside it so fast. Seems to be working for now. Will be changing the cover this weekend so I wont have to worry about it.
Question! I have seen several people mention oil leaking into the cylinder and wanted to clarify. When you say "cylinder", you mean cylinder tube, correct? This is my first experience doing work on an engine with the plugs down inside the valve cover. I have read posts where folks say oil on top of the piston. how can the oil get on top of the piston if the leak is the tube seal? On an older engine I know of no way for the oil to pass by the spark plug.
Thanks
Charrie
PS will be replacing the radiator soon I think. It appears to be leaking around the seal where the plastic top is clamped on. Guess the best radiator would also be one from Nissan? I see the after market ones run as low as $50 and a Nissan one is $125. I have read lots of bad reviews about after market ones just like the valve cover.
