Hi,
I'm new to this forum, but not necessarily new to automotive work. I'm just a hobbyist usually working on BMW's, Porsche and Jeeps. But, my wife has a 2008 Nissan Altima, 2.5 liter that is having some issues. It sounds like an exhaust leak, which is easy enough to fix after locating it. But, the transmission is shifting at lower RPM's than normal. They both started at about the same time, but I wasn't the primary driver when it started, so I can't be totally sure. My question is, are they related? Or is it possible they are related? Can an exhaust leak cause the transmission to shift at lower RPM's? Possible vacuum issues to the transmission? Other than that, the car runs fine. It reaches freeway speeds and cruises just fine. I should clarify that I'm looking at the tachometer and have not hooked it up to a secondary tachometer to verify the first one. TIA for all help!
