Passenger side power window
8.3K views 8 replies 4 participants last post by  halks01
#1 ·
My 2012 Altima 2.5s all power windows work except for the passenger side. It will not work from the driver side switch or the passenger side switch. The power lock works on that door from the driver side, but not the passenger switch. I am thinking I need to replace the entire switch for the window and the lock on the passenger side. Any help would be appreciated. Thanks. Mark
#2 ·
I would agree that the passenger switch assembly is the likely culprit. Check page PWC-33 (and PWC-88 for debug)
#4 ·
Ok, well, maybe it is the harness or BCM or window motor? However wires are most likely.
See PWC-77 for the window control path from driver controls, BCM and passenger control.
The door locking is DLK-158 to DLK-160
It is conceivable that some of the wires in the door loom have fatigued, or been pinched at some point. Probably worth doing continuity testing on the wires from the driver side switch connector to the passenger side switch connector and verifying that power is coming in to the switch as well.
#6 ·
Ok, I have found out that my Altima has a wiring harness for non anti pinch windows, and the door was replaced with a door wired for anti pinch window. So, the connector behind the glove box do not match. Does anyone know if you can get an adapter to make these two connect, or do you have to rewire them? Thanks.
#7 ·
Highly doubt there's an adapter, but as far as the window control goes, there are only two wires that matter.
Got a picture? Or, how many wires on the harness side connector, how many on the door side? PWC-273 for more detail.
